eb145's avatar
eb145
Explorer II
May 18, 2013
install rv power awning on home?
Has anyone tried installing an RV power awning on a house? I am thinking of putting an awning over my deck. The deck is 14' wide and 12' deep.
I am thinking of getting maybe a 16' awning, attaching it to the house so I can extend and retract with the push of a button. This would let me enjoy my southern-exposure deck more. The awning won't cover the whole depth of the deck but it would be nice to cover the whole width.
I have seen ads for installing retractable awnings on houses. I am wondering if an RV awning would work just as well and possibly be more cost effective.
Thanks,
Ed
  • Installed the awning from a 5'er we had in Falling Waters,W.V. on the house.We had the camper under a roof at the campground,so no need for it there.Was still on the house and working when I left MD 6 years ago.It was a manual one though.
    To just go and buy an awning,I'd go with Sunsetter,cheaper and way better quality.
  • wildtoad wrote:
    I assume an rv awning power supply is 12v so you'd have to handle that. You might go to sunsetter.com and get a free quote...
    Actually my Girrard awning is 120VAC. I have to either be plugged into shore power or turn on the inverter to work the awning.
  • I have a good friend I talked into a Sunsetter and it is considerably more robust than an RV awning. It's not hard to crank it in-&-out.
  • You will be happy if you install an awning, no matter which type you use. We also had a southern exposure deck and after the awning was installed, the rooms of the house adjacent to that deck stayed 15 degrees cooler than they did without the awning.
  • I think the homeowners model would be more economically priced than the one for an RV.
  • LOL
    Strange this question would pop-up.
    This coming week we're having two Durasol power awnings installed on our house.
    (You don't wanna know what the price is)
    Not sure why an RV awning wouldn't work on a house.
    Probably the way they're marketed maybe.
    I know the house awnings have a heavier cross arm structure versus the lighter weight side arms on the RV awnings.
  • A couple of the retractable awning manufacturers area also in the home awing business, so that's what you might be buying in any case.
    I think an awning designed for installation on a house might be more cost effective, and probably more suitable. There are some compromises in getting the weight of an awning mechanism down for use on a RV. My retractable awning at home was built more substantially than any power awning I've seen on an RV, sturdy enough to leave out even during thunderstorms. It was not power, however, a crank mechanism to roll it up proved adequate.
  • I assume an rv awning power supply is 12v so you'd have to handle that. You might go to sunsetter.com and get a free quote...
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
