JJBIRISH
May 31, 2013Explorer
Dutch_12078 wrote:JJBIRISH wrote:
The new Norcold units built by Pines RV Refrigeration and sold by David Force's Cooling Unit Warehouse are made using a thicker wall tubing than the OEM and a different coil pattern. Pines is indeed an Amish owned and operated company located on a traditional Amish farm in Shipshewana, IN. The owner is Larry Miller, and the tubing is formed and welded by his brother in law, Harley, at JC Refrigeration located a few farms down the road, prior to final assembly and testing at Pines. There is a very detailed post on another forum by someone who was in Shipshewana for repairs to his KZ TT and visited their facilities after winning a contest sponsored by David Force. They also do installations there.
Dutch
I don’t question that they (Pines or JC) are Amish… while there are many Amish craftsmen the term Amish built isn’t a guarantee of quality…. I am aware of their experience and use of absorption cooling in home, cottage, or cabin type refrigeration, but I don’t know that the different types and styles of cu are equal in quality for the different types of service… I know they say the tubing is 50% heavier but does that always equal better…
I know they offer quick and helpful service… But I also know they are a young maybe under 10 years old and small with a hand full of employees company, and in the grand scheme of things there is no track record… if information I have read is true there have been at least a couple revisions in the Amish built norcold 1200 cu’s in their short life… while we all know Dometic and NorCold have dropped the ball the fires are numbered maybe in the hundreds and failures in the thousands of the millions recalled… IMHO only, they might be the best, but I don’t have enough information to say the Amish units are better, safer and long term reliable…
As an example I couldn’t say they are better than one from, World Class RV Refrigeration that also build their own, www.rvfridge.com …
They have galvanized evaporator assemblies and many failures are due to sweating and rust in the evaporator when turning it on or off to use and store… they also use a different designed boiler assembly… while I have no way to prove it I believe the boiler assembly is the real problem with the fires… I believe they overheat and crack the tubing in the boiler, about the only way they would start a fire…
I haven’t had a problem myself and haven’t done enough research on the problem because of that, but I have my own suspicions of what and why the problems exist…
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
