Nicholsfamily05
May 20, 2016Explorer
So I located where the main wire from the pin box came out at the axles.
Removed most of the underbelly to locate it. I can see why they cover the under belly they don't want you to see the horrible work they do.
Anyways they had these really crappy wire tap kinda connections. Nice gauge wire down to a very small gauge wire.
So I removed all those connections between both axles and ran 14 gauge wire between them all.
Then heat wrapped all the connections to keep the weather out and secured each connection point so it can't move.
Guess what. Everything works now. Thank the maker!!
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
