Nayther,
There is no point in having more than 150 watts of panels per 100 amp-hours of storage. In your case that would be about 340 watts.
The reason is that at 85% state of charge acceptance rate of the battery bank is 12.5 amps per 100 amp-hours of storage.
225 amp-hours may only support a 1000 watt inverter. Six volt jars exhibit greater voltage drop under load. Larger loads on a 3000 watt may drive the input voltage so low that the inverter cuts out to protect the battery.
Lead acid cells are "happy" up to about 25 amps of load. 25 X 12 = 300 watts. They may support 75 amps or about 900 watts. Anything over that may push them HARD.
If real estate is a problem then if you have deep pockets move to LI jars. It solves the capacity problem, too. Caveat is not using the RV in cold weather.
There is no way I could boondock with a 225 amp-hour battery bank. Mine is 556 and I wish it were 1000 amp-hours.
