nayther
May 20, 2018Explorer
Inverter Help
Gathering up the materials/devices to start installing in our new rig which we'll have in a couple of weeks. Base line will be 2 T-105 GC 6 volt and 3000I Honda with remote start. Trailer is "solar re...
wa8yxm wrote:
LIFELINE AGM is the only fast charge I know of in the lead acid field. and then ONLY lifeline, not MK or Deka.
A pair of T-105's has about one KWH of usable poer bit more if you only use 12 volt stuff and do not invert. (you loose about 10-20 percent in conversion).
