nayther
May 20, 2018Explorer
Inverter Help
Gathering up the materials/devices to start installing in our new rig which we'll have in a couple of weeks. Base line will be 2 T-105 GC 6 volt and 3000I Honda with remote start. Trailer is "solar re...
Lantley wrote:Probably very small like a few milliamps. Off is fine while in use but for storage with no power I would disconnect a main cable.
On the subject of idle draw. When my inverter is off. The power button in the off position There are no lights on inverter are illuminated. I assume the inverter is drawing zero volts from the battery. I assume the inverter is not creating any parasitic draws off the battery.
