nayther
May 20, 2018Explorer
Inverter Help
Gathering up the materials/devices to start installing in our new rig which we'll have in a couple of weeks. Base line will be 2 T-105 GC 6 volt and 3000I Honda with remote start. Trailer is "solar re...
Lantley wrote:full_mosey wrote:Lantley wrote:
What you are really showing is the ability of AGM's vs. wet cell.
AGM can rebound from 11.45 without issue. I think running your typical wet cell at 11.45 may do damage?
It is not the rebound that I believe is the issue.
I don't believe your typical 220AHs of flooded 2 x GC 6Vs will hold the 11.45V like the AGM does, but will LVD instead. More weight, more footprint/space; less performance.
HTH;
John
Maybe I don't understand or maybe we are saying the same thing. Your AGM batteries started above 12 volts. They slowly discharged to 11.45.
But they will take a charge back to 12 volts without issue or damaging the batteries.
My thought is if a wet cell is discharged to 11.45 the cells will be damaged and the battery will suffer from being discharged that much.
not sure what LVD means ?
