- Isaac-1ExplorerAs a general rule on 120 volt 20 amp hookup, you can run 1 high draw appliance, along with 1 medium draw appliance, or several small low draw appliances. The Microwave, Air conditioner or electric water heater are all high draw, and draw around 12 amps each while running. The refrigerator is a medium size appliance and draws about 3.5 - 4 amps, battery chargers are medium to high depending on how low your batteries are they will typically draw 4 - 8 amps when charging. LED lights are very low, drawing a small fraction of an amp each, all lights in a typical RV if LED lights will likely add up to under 1 amp. Modern flat panel televisions will draw less than 1/2 an amp, maybe as little as 1/4 amp.
- Mike_LeClairExplorerYou certainly wouldn't have much fun as you would be continually stressing about power usage and running outside often to reset the breaker on the shore post. It can be done, however, as we did it in our Cougar 318SAB for a one week period. Again, not much fun. Can you get by w/o using the AC?
Cheers!
Mike - azdryheatExplorer
Mncst wrote:
No. Even 30 amps isn't enough for the AC and microwave in some cases.
We are looking at a campground that offers only 20 amp service. Is this enough to safely run our AC, TV and microwave? - Have something to monitor voltage stays above 105 in the RV.
Put the fridge and water on propane only.
Let the batteries charge for a couple hours before you try anything big. - DrewEExplorer IIIIt should be enough to run your AC (and pretty much nothing else) or your microwave (and not much else). I would suggest putting the fridge on propane assuming you have an absorption fridge. It would not be enough to run the AC and the microwave simultaneously, or either one with an electric water heater element or other high-draw appliance.
Televisions these days use not much power at all, so no concerns there...unless it's something unusual like a projector, or a really old TV. - Crazy_RayExplorerNot all at the same time
- Ranger_SmithExplorerMaybe not all at the same time. Must be a real old campground
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
