dodge_guy
Jan 06, 2017Explorer II
kokotg wrote:MFL wrote:
You should have no problem swapping the receivers. It is pretty straight forward, just follow torque instructions to keep it secure. Best be sure tow vehicle is up to the capability, to match the new receiver. There may have been a reason it had a light duty set up.
Happy wrenching,
Jerry
Trailer has a heavy hitch since it's a toy hauler....It's 7000 pounds dry, and our van's tow capacity is 10,000 pounds (which is right at the max weight of the new trailer, but we'll never come close to that; the main "toys" we're going to haul are bikes and maybe kayaks--we figure we'll top out at maybe 8500 or for a long trip). Current hitch receiver is only rated for 1000 pounds, and Jayco lists the dry hitch weight at 985.
I can promise you, you will be closer to 9k lbs loaded for a trip! 12.5% of that would be around 1125 properly loaded tongue weight.
So yes get a hitch rated for around 12k/1200 and you will be good.
And yes it is easy. With 2 people even easier. If you can loosen and tighten bolts you will have no problem. I would maybe also have a MAP gas torch handy for stubborn rusty bolts!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
