StephJohn2010's avatar
Nov 11, 2017
Is it crazy to leave water in your tanks in storage?
I am storing in Las Vegas so the coldest it gets at night are in the low to mid 20s for just hours at a time. I feel like it would be better for the rubber seals (keeping them moist) if I fill the grey and black tanks 1/2 full of water for storage. Do you think this is a good idea or not?
  • When I gamble in Vegas, I lose. :B
    Why gamble on the weather, drain the tanks and winterize.
  • You're storing your rig in Las Vegas. Gambling with the weather is your choice.
    Personally, I would drain the tanks and use RV Antifreeze as recommended above.
    Then you know the tanks won't freeze in the event of colder than normal weather.
  • Water wont keep the seals pliable. They will be fine without anything in the tank.
  • 1/2 full probably won't hurt anything, but also unnecessary. The seals you're concerned about are at the very bottom of the tanks. I just pour enough antifreeze into the tanks to know some got down to the drain valves. I dump some in the toilet to keep that seal wet, and a bit into the drains.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
