- valhalla360Navigator
TurnThePage wrote:
I've been looking at the mini-splits too. But the OP (and me too) is asking about a roof mounted unit that has similar characteristics to the typical mini-split. It doesn't seem that difficult from a manufacturing stand point. Maybe just not enough market to justify the upfront costs. Too bad.
The ones I've seen are mounted on the rear bumper. Probably best to beef up the support (vs the 4inch sheet metal bumper) but should be easy with a little welding.
General thoughts:
- This is not about battery powered air/con running on DC. These are 120v-AC units.
- On a larger RV, you can get a multi-zone with an interior unit in 2 or 3 units fed off one exterior unit.
Avoiding the roof mount is one of the big advantages in my mind. - magicbusExplorer II
Peter_Crowl wrote:
As I said, something like 20’, it was a couple of years ago. And he said he would have to coil any excess near the inverter. He preferred to bury it which is what started the discussion. Our shortest run was just long enough that there was no excess.magicbus wrote:
The guy who installed my house inverters explained that to operate properly an inverter requires a certain minimum length run between the inverter and the heat exchanger to operate properly. Something like 20’. He has done 3 installations for me so I tend to accept what he says.
Dave
Interesting. I have three in my house. None are that far apart. The line runs are - IIRC - 12 and 16' with the excess line coiled up behind the outside unit.
Dave - pianotunaNomad III
LittleBill wrote:
https://www.hotspotenergy.com/solar-air-conditioner/
Hi,
The link works--but trying to download the PDF of air conditioners doesn't. I'm on a fiber optic connection at 410 mbps; latency of 3 ms; loaded latency of 150 ms; and upload of 150 mbps.
The page is now behaving. Odd. - Peter_CrowlExplorer
I wonder if it's possible to kludge one together? - TurnThePageExplorerI've been looking at the mini-splits too. But the OP (and me too) is asking about a roof mounted unit that has similar characteristics to the typical mini-split. It doesn't seem that difficult from a manufacturing stand point. Maybe just not enough market to justify the upfront costs. Too bad.
- LittleBillExplorerhttps://www.hotspotenergy.com/solar-air-conditioner/
- Matt_ColieExplorer IIThere are 40~48VDC Mini splits available for the solar crowd. More than that, I cannot say. They are supposed to have really good SEER numbers.
Matt - Peter_CrowlExplorer
Dave
Interesting. I have three in my house. None are that far apart. The line runs are - IIRC - 12 and 16' with the excess line coiled up behind the outside unit. - magicbusExplorer IIThe guy who installed my house inverters explained that to operate properly an inverter requires a certain minimum length run between the inverter and the heat exchanger to operate properly. Something like 20’. He has done 3 installations for me so I tend to accept what he says.
Dave - SlownsyExplorerMany people in Australia has installed the household inverter type revers cycle 240V air conditioning in there FW, and also now’s of one using the roof type cassette, not heard of any failure for several years. I and many others have also installed household 240V inverter refrigerator which runs of a 350-375W inverter.
Frank.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
