bhannay's avatar
bhannay
Is this possible
I am looking to purchase this truck and this 5th wheel. Is it possible to tow this 5th wheel safely with this truck?
RAM 2500
TRADESMAN
6.4-LITER V8 MID DUTY HEMIĀ® MDS
CREW | 6'4" | AUTO | 4X2
AXLE RATIO
4.10
PAYLOAD
3,610lbs
MAX TOWING
15,950lbs
2014 Jayco Pinnacle 36KPTS Specifications
Sleeps 3
Slides 3
Length 39 ft 9 in
Ext Width 8 ft
Ext Height 13 ft 2 in
Int Height 6 ft 9 in
Interior Color Caramel
Hitch Weight 2485 lbs
Gross Weight 15950 lbs
Dry Weight 12770 lbs
Fresh Water Capacity 87 gals
Grey Water Capacity 87 gals
Black Water Capacity 50 gals
Tire Size 16
  • By the numbers it looks doable. It depends on your location, flat country, or mountains. Also depends on use, general Rving, or full timing.
    With FW loaded, you will be at the limit of the trucks capabilities.
    Jerry
  • The weight police are going to gang up on you and bet you half unconscious with a wet noodle.
    You really do not have much slack there.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Aug 30, 2022
