wadecool's avatar
wadecool
Is this truck and trailer combo doable for this trip?
I’m new here and have a question regarding towing. First off, I have a 2016 Silverado 4x4, crew cab with 3.08 gears. I’m aware of my 6100lb trailer limit (12,000 lbs total truck+trailer). I drive 100 miles round trip for work and if we ever do buy anything to tow it will be a ski boat. Due to the low profile of a boat and trailer and our not going further than 200 miles for weekend trips to the lake, I’m sure my truck will do fine in that scenario.
All that being said, we are planning a big trip to Yellowstone next summer. I’m looking to rent a travel trailer and pull it to Rapid City, through Black Hills, and on to Yellowstone. The camper I have my eye on to rent is a Keystone Passport 2400BH. Its about 28ft long, and has dry weight of 4730 lbs. I’m figuring on adding 500 lbs of cargo, propane tanks, etc. I’ll be deadheading to St Louis, picking up camper there and heading to Yellowstone. My truck has 1800lb cargo capacity and I’ll be keeping it under 1500 lbs total.
What is the opinion of those in the know of my trucks ability to tow this camper. I’d like to be able to maintain 60-65mph on the flats and obviously slow as necessary for mountain passes.
Thanks in advance.
  • APT wrote:
    Install a heavy duty transmission cooler, use tow/haul mode, and M4. Flush all the fluids, buy a proportional brake controller and you'll be fine.
    According to the RPO codes on sticker in glove box, it has the HD transmission cooling (KNP code). I'm putting a Tekonsha Prodigy P3 controller in the truck before we go.
  • RTCastillo wrote:
    First thing I'll look is the truck's operating manual. It should clearly state towing limits.
    Owners manual says 6100 lbs tow limit, 12,000 lbs for both truck and trailer.
  • If you have the 5.3 V8, it should do the job. I'm sure you know that TT will put you right at truck's towing limit. You will likely add more than 500 lbs to trailer wt. You will need to have some water on board while traveling, I am thinking you'll add 1,000 lbs minimum to trailer for that length of trip.
    Everyone has a different comfort zone, when it comes to towing. That camper appears to be a bunk house, and you don't say how many passengers will be going on the trip. Everyone/everything in the truck counts against the truck's GCVWR.
    Anyway, when towing right to the vehicles limit, some will say it was a nightmare towing experience, and the next person say the tow went really well.
    Jerry
  • Install a heavy duty transmission cooler, use tow/haul mode, and M4. Flush all the fluids, buy a proportional brake controller and you'll be fine.
  • “I’m figuring on adding 500 lbs of cargo, propane tanks, etc” Not likely. Fifty gallons of fresh, grey and black water will be 412 pounds alone.
    “I’d like to be able to maintain 60-65mph on the flats “ The rentals trailer tires are rated for what max speed?
  • First thing I'll look is the truck's operating manual. It should clearly state towing limits.
