Jerry_L's avatar
Jerry_L
Jensen DVD player
Have a 5th wheel with a Jensen DVD player causing me lots of frustration. When playing a DVD, it will freeze/stall, pushing the forward, reverse button will not work. The DVD has to be ejected and reinserted. I keep the DVD on fast forward, past the point of it sticking, to watch the DVD. I initially thought it was the DVD disk. I played the DVD in my home and there was no problem. Has anyone experienced this problem with the Jensen DVD equipment and if so, how did you fix the problem? I've been informed Jensen DVD/stereo systems are bottom of the list and should consider replacing it.
  • Ours has the same problem, wife cleaned the discs and we will test them soon…….doubt if it helps.
  • If you replace your Jensen with an auto unit that only has one or two speaker outputs, the signal can be split again using a speaker selector switch. There are a lot of them out there and Niles is one brand known to make a quality switch.
    Niles switch
  • I don't know what year or features your system has and what outputs you need from the disc player. I needed to replace an older DVD player, so I went to Best Buy and purchased a BluRay player with a was brick, discarded the wall brick and went with a 12volt cable. The player I bought has only one HDMI output and so I bought a Splitter and cable for the rear TV. Often the DGKs are in back and want to watch the same thing we have playing up from, ergo the splitter and cable. There is a greater selection of players that use 120 volt but the simple one works great for us.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
