Halmfamily's avatar
Halmfamily
JT Strongarms on Hydraulic Landing Gear
Can you install JT Staongarms on hydraulic landing gear? All the pictures I see are on electric landing gear. Looking at their website I see no information on this. If you can or have, how do they connect to the landing gear or pad? Thanks for the help.
  • I'm in the same boat, I can't attach mine like they would on regular electric legs either. I have the BAL Lock Arm stabilizers and they unfortunately will not work with that weld on device.
  • Helmsey wrote:
    Lippert makes a weld on mount for the hydraulic landing gear. Sorry I don't have a link, but it is out there.
    Edit: This is what I was talking about: Clicky
    Thank you Helmsey this is what I will have to use. My pad are not bolted to the landing gear, assume screwed into bottom. Now to find a local welder.
  • Lippert makes a weld on mount for the hydraulic landing gear. Sorry I don't have a link, but it is out there.
  • Have had a set on our Landmark for 5 years, no issues at all.
  • I don't see why it would be an issue. They connect the same whether you use hydraulic or electric stabilizers. They have a pin that goes through in place of the present pin that holds on the pad.
    They are an excellent addition to any trailer. I won't have another without them.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
