Campsask's avatar
Campsask
Just installed Blue Ox Sway Pro and have a question
Hey all, I just installed my new blue ox sway sway pro and it went pretty smooth. Very easy to do.
The only problem I have is it looks like the front of the trailer is a little high. I have the hitch assembly as low as it will go. I pulled it around the block a couple of times and it seemed to be fine but I'm new to this so I don't know.
I had to flip the receiver upside down and use lowest holes or else the ball would of been way to high. Is this normal?
I measured the front and rear of the truck and they are pretty close. Front is 38" and Rear is 38 1/2" or so.
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
  • Just a thought, but are you sure you have sufficient weight transfer going on here? The Blue Ox Sway Pro is quite different from other WD systems in that those spring bars, when properly loaded, should bend quite a bit but from your pics it appears yours aren't.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
