jwmII
Aug 25, 2015Explorer
Wishbone51 wrote:
I have a Norcold 1200 series fridge in my trailer. Normally when connected to shore power, it operates just fine. It also works just fine on propane. Better actually, according to the remote thermometer that I installed.
Normally when camping, connected to shore power, it's nice and cool inside the trailer, and when opening the fridge, the fridge air temp goes up a degree or two.
I noticed when I loaded the fridge yesterday and the trailer interior was hot, the fridge temp went from 34* to 45* very quickly and took all night to come back down.
I've never been dry camping before (going this weekend), and it might be hot inside the trailer causing a similar situation when using the fridge. Should this be an issue?
Or since the thermometer is measuring the air temperature and not the food temperature, will it be OK?
Any suggestions to maintain the cold when trailer air temps might be high?
Sometimes I think that the thermometer I installed is just another thing to worry about :) . Just need to relax and go camping.
Minimize opening the door. Know what you are after before opening
the door. Get it and get out. If you have children along you will
need to chat with them about excessive trips into the fridge and why
they can't hold the door open while they look for something that they
didn't even know they were after.
The worst thing you can do is put a thermometer in the fridge. It
will make you nuts chasing around after temps that are probably
unattainable and that will never happen because you are opening the
door too often and letting all the cold air out while you are
checking the temperature.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
