doxiemom11
Jul 01, 2013Explorer II
From what I have read,reflectix on the dual pane windows will heat the glass enough that the seals melt, warp,deform and you no longer have sealed dual panes. Moisture then gets between the panes of glass and etching starts. You then have to replace the glass. In researching dual pane window replacement, I found this information. We were also told this was probably the cause of the seal damage on our passenger side cab windows.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
