TyroneandGladys
Jun 29, 2013Explorer
Keeping it cool when It is 100 Plus
A AC if working properly will cool the incoming air by 20 degrees. In other words if the temperature in RV is 100 degrees the air coming out should be 80 degrees. Some tricks to keeping cool in an RV when the outside temps go over 100 degrees are.
First start cooling early It is much easier to maintain a lower temp than to let it get to 100 degrees and then try to cool it down.
Second reduce the area to be cooled examples cabin area, overhead bed, bathroom and bedroom. After the sun goes down open up these areas if they are going to be used.
Third cut down heat from the sun on your RV and on the windows. Examples park where you can get shade in the afternoon if possible. If no shade is available either park facing West since the front of you RV is smallest surface area there will be less heat gain than the afternoon sun hitting the side of your RV or park with your awning side to the West and put your awning out to shade the side of your RV. Use a windshield cover on the outside of your cab windshield and door windows. Tint your windows if possible. Window awnings will also help. Cut Reflective Radiant Barrier to fit the inside of your windows or use aluminum foil. On our cab over window we have it tinted and a piece of 1inch solid styrofoam insulation secured to the inside of the window with double sided tape.
Fourth do not use the range or cook top when the sun is out if you must use these wait till nighttime.
Fifth maintenance clean your AC filters. Clean the outside coils on the AC on the roof.
Sixth use some fans a fan will not make it cooler but it will make it feel cooler
