robert_fletcher's avatar
Aug 12, 2015
kia soul towing
anyone has towed a 2015 kia soul? Do you just put itin neutral and putkey on accessary? will battery run down with 6hours of towing?
  • We have a hyudai elantra, so yes it is a manual trans and yes key on, all accessories off. Depends on what you have as options. When we towed ours 1st time battery was dead at 1st stop. Added a charge line and no issues since. The Hyundai company is the owner of kia so the 2 vehicles are basically the same.
    By key on I mean in accessory position so the wheel is unlocked. I had the wiring kit installed that uses diodes to keep the lights operated by the coach.
  • When we looked at the '15 Souls, we were told that only the base model with a manual transmission can be towed.
    Is that what you have?
  • What instructions does the Owners Manual have for "Recreational Towing"?
    Does the steering lock? If not, there is probably no need to put the switch in the ACC position!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
