- Big_KatunaExplorer IIHair can build up around the shaft and needs cleaned.
I used mine 10-15 times a year 150 gallons at a time and my impeller needed replaced every two years. Vanes break off. West Marine keeps a hook full of them for a reason. - Bird_FreakExplorer II
Big Katuna wrote:
Ditto!
When that macerator jams you have to deal 1-2 gallons of raw sewage in your water bay. Happened to me TWICE.
With a tank rinser and a quality 3" hose, I never have to deal with a drop of raw sewage. - MudChuckerExplorerOMG - Sorry sorry to the OP for annihilating the thread.
but... since the damage is done...
Bumpyroad, you mentioned that you dont consider dumping a race, neither do I, but I like to be efficient, and considerate of others in line on the hot summer days at the various dump stations across the continent and dump as timely as I am able.
I'd buy a macerator so I can fertilize my neighbours garden for him...if I knew I could do it quickly :) ^Kidding^
Concerns about the lack of "woosh" leaving chunks behind tho. - chuckbearExplorerI didn't see anywhere in the OP's initial posting or question, anything about macerator pumps verses sewage hoses. How about starting another thread? Chuck
- BumpyroadExplorerif your macerator pump clogs, you have too much fiber in your diet. nothing in my black tank but TP and everything else has gone thru a body.
but of course I use my macertor pump to dump my black tank at a campground. every third night or so I get a FHU site and dump at my leisure, untimed of course, as I am not so cheap as to use the public dump to save $3.00 a night. and it always seemed to me when using a stinky slinky that there always a cup of "water" caught in the corrugations that ended up either on the ground or on my shoe. I suppose if I took 30 minutes to work the SS back and forth/up and down, most, but not all of that waste would actually go into the sewer opening. and putting away and storing a "hose" vs a stinky slinky is no contest.
bumpy - irishtom29ExplorerDumping your tanks with a normal hose is a very simple job, I wonder how even a klutz could manage to make a mess of it. Maybe some people don't actually make a mess but have a strong fear of doing so.
- LarryJMExplorer II
Bumpyroad wrote:
throw away the stinky slinky and buy a sewer solution of macerator pump instead.
bumpy
IMO for 99% and normal sewer connections at a CG that is a TERRIBLE solution to basically a non problem. You will also not get near the "FLUSHING VOLUME" from something like that molasses slow macerator pump system that you can thru that 3" "FIRE HOSE".
IMO a macerator system is only necessary for "EXTREMELY" long (50 to 100') distances or uphill situations.
Larry - SoundGuyExplorer
Big Katuna wrote:
A macerator is over $200 and is slow and can jam and requires maintenace every so often. And you still have a poop hose; its just a smaller diameter.
The pump will only jam if you're careless and allow "stuff" in the toilet that shouldn't be there in the first place. :W
I've had my Flojet Waste Macerator since 2006 and it's required no maintenance at all. Last year was the first time I've ever looked at it when I decided to replace the seals ... now that I have I see no reason it wouldn't go another 10 yrs without any attention. :)
No, no "poop" in the output hose - once macerated by the stainless steel chopper blade what enters the hose is essentially water with just small particulate content. :)
Regarding comments about "how long" it takes to service the tanks with a macerator my answer would be it takes as long or as little time as you want. I use mine primarily for servicing the tanks at home so I never have to line up at a campground dump station ... my time is my own, no one is lining up behind me, why I would care "how long" the process takes is a mystery, I've never given it any thought. :)
But I guess those who've never owned one would know better. :S - cmcdarExplorerI always use a slinky at a dump station, but never see or drop sewage.
Surely, you are not using a macerator at a campground. - BumpyroadExplorer
cmcdar wrote:
"at least with the macerator I don't have to clean "stuff" off my shoes that always happened to drip out of the hoses with the horrible stinky slinkies.
bumpy "
What? You must be dumping at home. Where and how are you dumping when you use your slinky?
where are you dumping that you don't use a slinky? do you just pull up sort of close to the "trough", and let er rip?
back when I used a slinky, before I wised up, I always hooked the slinky from outlet to dump input.
bumpy
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: Apr 08, 2026
