walker111's avatar
walker111
landing gear issue
Hi all
Own a 2014 Voltage 3305. This past weekend the landing gear seemed to cause me problems. When I was hooking up sunday to leave, the gear was very slow and would only run about 3-5 seconds and then stop all together. I would wait a minute and it would run 3-5 again and stop.
I ran the on board genset, I plugged in . Nothing helped. Batteries are fully charged. Was able to get the trailer up enough to hook on and then same issue at my storage facility.
Think the motor is done?? It has been slow for a while but not like this . Is the manual overide at the top pf the leg on the driver side of trailer?
Thanks for any response.
  • Also make sure all connections are clean (ground too) If the wires are marginal, a weak connection can reduce voltage for a motor to run slow. And low voltage can kill a DC motor in short time.
    Just for snots and grins, use a good pair of jumper cables to by-pass all the factory wiring. Bet the motor runs much faster than new.
  • I will go to storage compound today or tomorrow and update
    Thanks for info Jerry
  • Have you ever lubed the legs (screw drive)? When mine run slower, I added a couple lever strokes to each one, per manufacturer recommendation. Doing this perked them right up, motor run faster. Mine has zerks on the legs about 8"s or so from top of leg.
    If yours need lubing, it may add extra load to motor, causing solenoid/breaker to shutdown, and reset.
    Jerry
  • I doubt fuse also for that reason. Mine has always been slow for raising the trailer. Could need a new motor.
  • If the leg motor works at all, it's unlikely to be the fuse. Our 2010 Fuzion 383 leg motor finally bit the big one. It never worked very quickly, and just kept getting slower and slower. I replaced the motor/legs with the Bulldog system with separate motors for each leg. An excellent solution IMO. The legs no longer struggled. The trailer is gone but the Bulldog system was great.
  • It is electric motor. I will go to storage today to troubleshoot. I will look for an inline fuse and swap out. The motor works but very weak then stops as I described so the fuse is working but will check it out.
    Thanks for reply
  • Sorry to hear about this.
    What kind of landing gear do you have? Electric w/motor, hydraulic, etc.?
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: May 21, 2013
