miatared's avatar
miatared
LCI Trailair air pressure ?
Being the new owner of a 'new to us' 2010 Sabre 31REDS fiver equipped with a Trailair pin box, I am trying to figure our the air pressure I am suppose to maintain it at ? I cannot find any user manual online at Lippert either..
O' wise one, can you enlighten me ?
Regards,
Denis
  • Air to the mark and try it once loaded. Too much air and it will not give and ride rough. Too little air and it will be too soft and bottom out. You can go a little over or below the mark, but not too far.
    Ken
  • As previously stated, the requird air pressure is rig dependant. My Coachmen is only 10k loaded, and the trailair only requires 42-45 psi.
  • Somewhat depends on exact pin box and weight of your trailer. Mine has pin weight of 3600# and I ran 60# when using L05 model which is long pin box and large air bag. Changed pin box to L15 which is 9" shorter and considered the medium length box. It has a smaller diameter bag and same trailer now takes 100#. It all comes down to you want the trailer to float about at the base of the arrow heads on the shock sticker. Randu
  • I run about 75-80lbs. Any less and it bottoms out, any more and it doesn't absorb the shock as well.
  • Thanks I will do that, so I guess the pressure is somewhat irrelevent, as long as the top of the yellow arrow is visible once hitched.
    Much appreciated.
  • There should be a mark on the shock absorber on the front of the pinbox. If not you should start by airing it to the center of the travel. This has to be done while sitting on level ground and without any pull on the hitch. Then air up or down to get the best ride. Too little air and you will get a lot of bounce and too much and it defeats the purpose of the air bag.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
