kyle86
May 01, 2016Explorer
Leaf spring angle / geometry with adjustable hangers
My 5er has adjustable hangers. All the hardware sits in the top most holes. I want to install a new equalizer between the axles like the ex flex but am not sure if moving from the top hole to the bottom hole on center hanger will adversely affect anything with the geometry or spring angle. My concern is there will not be enough clearance for the ez flex using the top hole. One of my hangers is bent which prevents me from lowering all the bolts. My other idea was to just cut off the bottom of the hanger if need be.
Is there any particular geometry needed on axles or can the springs be angled any way desired? Thanks!!
