Mr__Steve's avatar
Mr__Steve
leak above driver door window ....question
hello..I have a leak coming from the window above the driver door in my motor home. It seems to be coming from metal framing around window. I purchased DAP caulking, then I began to wonder if there was any special caulking I should use since its a motor home not a stick house? The outside of the frame has a rubber seal around it, I assume I apply caulking under the rubber? THANK YOU!
1 Reply
  • If you have a window leaking, the only fix is to remove the window, clean the area, apply a layer of butyl putty tape, reinstall the window. Once it is secured and the excess putty is removed, apply a bead of Dicor for verticle surfaces around three sides of the window.
    Both the Dicor and butyl putty tape can be found at any RV parts house.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
