wickedstang03's avatar
Jul 19, 2015
Leaking toilet.. anyone use a wax ring?
So I recently had a vinyl wood planks the 2mm peel and stick installed in my camper and now the toilet is leaking around tje base... after looking at it it looks like they lifted the toilet up and slid the planks under it... looks as tho I need to replace the ring.... anyone ever use a wax ring? Would I need an extra thick one to make up for the flooring?
    YES
    ... Would I need an extra thick one to make up for the flooring?
    NO, but I did buy the one that had the built in cone to be safe. Never had a problem.
  • I would not use a wax ring. The rubber ones cost more but work better with the vibration and shock found in RVs. If they could get away with wax the manufacturers would use them and they don't - at least not in any I have seen or heard about.
  • You can get rubber rings now at box stores. I'd be more comfortable with something more continually compliant in a trailer with all the bouncing around than wax that will be compliant when placed but jostling might not keep it that way.
  • I agree with Bob, if it's only 2 mm then the seal should still work. Maybe buy a new one and try it.
  • It's possible that when they reinstalled the toilet they didn't get the rubber gasket seated correctly. I did that when I had to remove mine once. You need to be careful when setting the commode down making sure the rubber gasket isn't pinched on one side.
    Since you've only added 2mm in height I can't imagine that the standard rubber gasket wouldn't work and you should be able to reuse the one that's there as long as it didn't get damaged with a cut or tear.
  • It's an ordinary closet flange so you should be fine with a thicker wax seal.
    Don't go too thick though, the wax will distort and invade the interior of the flange causing blockage (I learned this one the hard way..).
  • There is usually a flange where your toilet bolts to.If the floor boards raised the toilet,you may need a thicker wax or neoprene gasket.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
