BarneyS
Mar 27, 2014Nomad
It is probably coming from the place where the cable enters the base of the antenna. There is a rubber covering that often works its way off. I put some caulking compound on mine and then replaced the covering.
While you are up on the roof attending or checking that, take a can of Silicone spray up there and squirt a generous amount down the antenna where it cranks up. That should be done a couple of times a year to keep the thing operating smoothly and probably prevent the O rings from leaking.
Check out the subject on this site.
Also, page 4 of this manual tells exactly where to put silicon spray on the antenna to keep it from leaking. There are a couple of other spots that I didn't mention above.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
