dcmac214's avatar
dcmac214
Leaky Toilet Fix
At least it appears to be fixed - 2 days now and still holding.
Vinegar & baking soda.
Posting because my search for a fix went back to (2010?). Toilet seal wouldn't hold water last year, would leak dry within a couple of hours. Thought I needed a new seal but search convinced me to:
(Water turned off of course)
1. Put repeated doses of vinegar in the bowl to dissolve/soften any hard water deposits (and if there's one thing you can say about the water around here it's that it is HARD). I did this for almost 2 weeks.
2. Using toothbrush, fingers & hot soapy dish water, clean seal & ball valve as best I could. Still leaked, but only half as badly.
3. Put 1/2 cup baking soda in bowl followed by couple cups vinegar. Wait until all bubbles gone. Open valve and scrub everything with fingers & toothbrush, repeated several times.
4. Again a hot soapy dishwater wash & rinse.
If it still leaks it's a real s-l-o-w leak. The quart or so water I put in the bowl Saturday evening doesn't appear to have gone down any.
FWIW, no, I don't wear gloves washing the toilet (nor do I when dumping the tanks). Neither I nor DW are squeamish about germs. That's what soap & water are for. And we've handled plenty of 'that stuff' taking care of our own babies & grandbabies.
  • When water evaporates from the bowl it leaves behind all the minerals that were in the water. So don't let the water evaporate. I either float mineral oil on top of the water or cover the commode with Sarah rap. Both work very well at keeping the water from evaporating therefore keeping the seal soft and pliable.
    R
  • Lemon Pledge for the final treatment. Works like veg.oil/olive oil.
  • CLR to remove scale/lime build up. Scrub seal top/bottom and blade/ball valve then rinse clean
    Veg. oil/olive oil to lube/condition seal
    I always pour a little oil in bowl anytime rig is not being used for week or more......especially over winter
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 08, 2026
