rseymour21's avatar
rseymour21
Learn best from your mistakes
I read a lot here and have learn a ton of stuff! But sometimes you'll remember your mistakes.
I don't camp a lot during the heat of the summer here in Texas, but some times, you gotta do what you gotta do!
Anyway, my DD and her hubby wanted to go camping with us (first time for hubby to go with us)! DD is expecting and I wanted to try and make her comfortable. She wanted to bake a froze pizza, well when you don't really think things thru, I'm firing up the oven! About half way to being done, I just sit and watch the temp rise! No, not in the oven, inside the camper. Started about 77 and watch it climb right on to about 86. Lucky for us it wasn't one of those really HOT days! I informed DW that there will be no more oven use during the summer, unless we are at 8000 feet!
  • If you're thinking of using a Pizza Stone on a grill, don't use the very cheap ones made from soapstone. Look for cordierite mentioned on the packaging. They are much more resistant to thermal shock (making them less likely to crack).
    I've worked in kitchen stores for nearly 6 years. I like to recommend things that will get the job done AND last for more than one use.
  • We use our oven on every trip. We turn on the exhaust fan over the stove/oven and it sucks the heat venting out of the back stove. Fiver does not heat up and once oven has cooled down turn the fan off.
  • In our trailer the fan does not vent outside, just blows inside thru a screen. Would love for someone to explain how to bbq pizza. Dave
    Same here! But then, I did replace my fan with a nice quiet one so we don't mind it being on.
  • I make pizza on the gas grill at home. I buy the dough, roll it out, coat both sides with a little olive oil. Put the flattened dough on the grill for maybe 5 minutes, flip add your toppings (to the already cooked side) and close the cover. Cook until your bottom crust and toppings are done (5 to 10 minutes). Nice and crispy.
    Friday is pizza night, which coincides with heading out camping for the weekend. We have cooking pizzas in the camper oven down to a science as these RV gas ovens tend to easily burn the bottom of take-n-bake pies.
    It's a gas oven. Of course we turn on the hood fan. If that doesn't cut it, a minute or two of the Fan-Tastic fan will provide plenty of ventilation.
    We don't hesitate to use the oven. That is what it is there for.
    -Eric
  • We don't use our oven for the most part. In fact, we were just talking about how hard it might be to install a dishwasher in its space.
    U must be not in 100 deg. temps with the ACs working their hardest with a 40 ft camper and HOW acs are placed :)
    fan works so much for us, then it is all ABOUT the heat being generated.
    I think it is truly about location, temps outside, acs ya have and all that.
    a fan over the stove works well in certain situations, not for most I would think if it was OUR temps etc. during a certain trip.
    Live and camp in Alabama. 90°'s and high humidity, typical Alabama summer weather. We have a 40' fiver, four slides with a 15000 and 13500 BTU A/C's. The minute the oven comes on to the time it cools down the vent fan is on. We have one A/C over the kitchen ducted to front living room and bathroom, ducts to rear bedroom have been closed off. If needed we will turn on rear non ducted bedroom A/C and leave bedroom door open. Yearly I pull apart my A/C's and clean both evaporator and condenser coils to ensure optimum cooling.
    On a typical summer day only main A/C stays on set to 74° and it will cycle on/off until around 3:00 pm and then stays on until 8:00 or 9:00 pm.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
