gbopp wrote:
luberhill wrote:
So if I want to add bleach and get it to the water heater too I have to dump it in the hose ?? Yes.
Then turn on hose so pressure will push water in the tank, then turn hot and cold water faucets on till I smell bleachy
But when all done and I want to drain everything including the water heater just st empty the tank via drain then with pump on turn on all faucets,, this will drain most of the water heater too ??
Remove the plug at the bottom of the water heater to completely drain the tank. It may be a plastic or metal plug.
But to drain the majority of the water heater just leave pump on after emptying th main water tank
No tying the main water tank and open faucets ??
Why can’t I just dump bleach in the connection at the full ??
