tsetsaf's avatar
tsetsaf
Explorer III
Feb 10, 2014
Length vs weight
We are selling our current trailer and buying a new one. On paper the new one has a gvwr 1000 greater than our current rig and a dry weight about 500 lbs greater. In the end we will end up with a 500 lbs heavier rig ready to roll down the road.
New trailer is a triple axle.
New trailer is 7' longer.
Truck is rated to handle the weight; should there be any concern about the length?
  • blt2ski wrote:
    MIN WB for ANY trailer is 110" ie up to 20'
    Then you need 3" of WB per 1 additional foot of trailer length
    First -- the "rule of thumb" does not say a TV with WB less than 110" cannot tow any trailer. It just uses 110" as an arbitrary starting number for the "relationship".
    Second -- the "rule of thumb", which frequently is attributed to the RV Consumer Group, says 20' TT for 110" WB, and then add 1' of TT length for each additional 4" of WD -- not 1' for each 3".
    IOW, all those people with 130" WB Suburbans should not be towing trailers longer than 25' and a 157" WB pickup should not be towing more than 29' (if you want to believe the "rule").
    Third -- AFAIK, nobody has ever produced any data or analysis to substantiate the "rule".
    Ron
    With that rule, I guess I can't tow any more...
  • Aside from corners in tight urban streets, parking lots and backing into spaces, no. The longer trailer wheelbase tends to track better and be more stable, as does a triple axle. It will probably feel better than your old setup.
    Brian
  • Reality no.....
    altho there is a little rule of thumb some folks follow, goes something to the tune of.....
    BUT, I believe this rule of thumb came about back in the days of staion wagons, sedans and the rare half ton truck pulling trailers..... with the more prevalent addition of heavier suspension trucks, longer body styles etc.... I personally am not sure this works completely, but it is a rule of thumb one can follow.......
    THen again, the rule of thumb I was told to follow way back when I personally learned to tow in the late 70's, before GCWR ratings existed, max trailer wt was two times the rear axel rating of the tow rig......works well for me. As I find when I start hitting the 2.25-2.5 range, the tail wags the dog more than the dog wagging the tail!
    Follow above rules as you see fit!
    Marty
Looking for advice before your next adventure? Look no further.25,126 PostsLatest Activity: Apr 18, 2025
