willald's avatar
willald
Explorer II
Oct 29, 2013
Lesson learned, about winterizing using blow-out method
Well, temperatures here have started dipping down to freezing, so Saturday I had to officially end the camping season, and winterize the RV.
Anyway, I went through the usual procedure I use for winterizing - Remove water filter, run some antifreeze through/into the water pump, run air compressor to blow out all water lines, pour antifreeze down all traps/drains, etc. Have always used compressor blow-out method, and it works great for us.
Well, I'm finishing up pouring antifreeze in the bathroom shower and sink, when CO detector goes off. Cannot get it to quit alarming, sensing presense of CO in the RV. I open several windows, turn on bathroom fan, it finally quits. Turn off bathroom fan, a few minutes later it (CO detector) starts squealing AGAIN. I turn fan back on, let the fan run (with several windows open) for a good 20 minutes, CO detector then turns off, and everything is good.
At first I thought that this was a bad CO detector. Have had that happen before. However, the fact that after ventilating the RV for a while it cleared out....Well, seems there must have been CO present inside.
Oh, and no, the generator was NOT running, there was no gasoline engine running anywhere close by, no indication whatsoever of CO (and all gas appliances were turned off, gas bottles closed, shut off).
Soooo, apparently in the process of winterizing the RV, SOMEHOW, enough CO gas got in the RV to trip the detector. After thinking a bit, I realized what must have happened:
Air compressor was sitting in the garage when I was running it, when blowing out the lines. I run a long 100' air hose from compressor in the garage out to the RV when inflating the tires or winterizing. Compressor has always stayed in the garage.
I can only guess that there must have been some CO gas lingering around in the garage from when one of the cars pulled in earlier, and the compressor sucked it into its tank when running. Have been using compressor blow-out method for winterizing for years, and never had this happen before. But, makes sense how it could happen, when compressor's air intake is just a foot or so off the ground and inside the garage where the cars are.
Anyway, lesson learned from this: I think from now on when winterizing, I'm going to first purge the compressor tank of all air in it, roll it outside away from the garage, before turning it on. Hopefully that'll prevent any CO gas from getting sucked into the air compressor, and blown through the pipes and into the RV.
Has anyone that uses compressor blow-out method, ever had something like this happen? Any other ideas/theories on what may have caused the CO detector to go off in this case?
  • in 40 years never had this happen. I agree with your deduction, unless your dog was in the coach with you. I will say one thing about your CO detector, it must be ultra sensitive. Again the dog could set it off, I have heard of lots of people finding that to be their problem.
  • We use the Blowout and Antifreeze method but have the VAIR compressor so it's is outside with me at the street water connection.....
  • Guess it could have sucked CO2 into compressor tank. Good to know. I have a huge floor mounted air compressor in shop. Never gave it much thought before.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Aug 30, 2022
