Bedlam
Jul 03, 2017Moderator
Some things to consider:
1. You will not be able to see around the camper and will need at least one spotter
2. Many front receivers are low rated and your front suspension may not support the tongue weight
The second item is something you need inspect more often if you are over operational limits. Check attachment hardware and welds after use and look for front end alignment issues.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
