DrewE
May 08, 2015Explorer III
I'd think it's pretty much a given that things in the RV will shift and squeak and settle and move with respect to each other a little. RVs are somewhat flexible, at least ones affordable to mere mortals. (For what it's worth, the living room floor, among others, in my sticks-and-bricks house also moves and squeaks a bit when walking over it, and it's not in a moving trailer of any sort.)
I'd be surprised if your counter shifted enough to be out of level in comparison to the fridge sufficiently to cause fridge damage. A couple of degrees out of kilter is actually quite a bit—if you use 2x8's or 2x10's for leveling, each thickness side-to-side is very roughly around one degree. If you're easily able to make a round omelette rather than a moon-shaped one on your stove top, your fridge should also be happy.
Looking for advice before your next adventure? Look no further.25,209 PostsLatest Activity: Aug 28, 2026
