F1bNorm
Dec 20, 2014Explorer
dahkota wrote:
We have the ready brute elite. While I have no problems carrying it, hooking it up alone is another matter. If you are very close to perfectly aligned, you can hook one side then the other. If you are off a little bit, it is a struggle to do it alone as the arms are awkward. ---snip---
I think I have the same problem. Because one arm is setting on the ground and the other you're trying to attach is at too great an angle. I have an easy solution. I have a cheap HF tote that has a rigid handle. I set one arm on the tote while attaching the other. Makes it easy. The tote I use for storing the wiring harness, safety cable, spare pins and a pair of work gloves. Before the tote I used a small step stool and then the cardboard box I use for the accessories.
Norm
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
