dahkota
Dec 20, 2014Explorer
F1bNorm wrote:
I think I have the same problem. Because one arm is setting on the ground and the other you're trying to attach is at too great an angle. I have an easy solution. I have a cheap HF tote that has a rigid handle. I set one arm on the tote while attaching the other. Makes it easy. The tote I use for storing the wiring harness, safety cable, spare pins and a pair of work gloves. Before the tote I used a small step stool and then the cardboard box I use for the accessories.
Norm
Thanks Norm! While I don't know what an HF tote is, I think I get the idea. I've tried resting the 'other' arm on my bumper but always manage to knock it off. I will try with a large box I have - it will probably save me quite a few bruises!
Now, if you have a hint for the pin that won't come out...
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
