gotsmart
Dec 21, 2014Explorer
dahkota wrote:
.... If you are off a little bit, it is a struggle to do it alone as the arms are awkward. Being 5'6" tall, my reach isn't as long as others which may cause some of the awkwardness. I think the arms of any tow bar would also be awkward, but I have no experience with them.
I'm 5'3" tall and can still hook up the car even if it is a little bit off. Here's my trick to doing it:
Caveat: If your toad does not have a base plate design that is similar to my Roadmaster Falcon 2, then these instructions aren't for you.
1) drive the toad close enough to the MH so that the tow bar's arms can reach the toad's base plate without having to be fully extended. Getting close enough so that the tow bar arms need only to extend about 1/2 or 3/4 of their travel length is pretty good. At the same time you're trying to align the toad with the tow bar as best you can
2) Go to one side of the tow bar. Lift the arm and extend it. Lay the arm down on the baseplate and/or baseplate cross arm. (this is the step where you would have your spouse/partner hold the tow bar arm in the air while you connect the other toe bar arm to the toad)
3) walk around the toad to the other tow bar arm.
4) Lift the arm and extend it. Be mindful that the other arm is just resting there - and not connected yet. Lifting the arm too quickly or not smoothly could cause the other arm to fall to the ground. If the other arm falls to the ground then you have to go back to step 2.
5) connect the tow bar arm to the toad.
6) walk around the toad to the other tow bar arm that is resting on the baseplate and/or baseplate cross arm, and connect it to the toad.
Do the same when disconnecting the tow bar arms. After disconnecting one arm, rest it on the baseplate and/or baseplate cross arm - and then go disconnect the other tow bar arm. This makes disconnecting the 2nd tow bar arm easier because there is less force acting against the 2nd tow bar arm with the disconnected arm resting on the baseplate and/or baseplate cross arm.
Roadmaster baseplated with cross arm attached between them:
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
