- I agree with Langley. 40 ft is to long and heavy to rangel for 1 person. Either cut yours down or by a 25ft and a 15ft extension and only use what you need.
- LantleyNomadA 40' 50 amp cord is too big and heavy for regular use. Get a 25' cord and have a 50 amp extension cord available for those rare times you need a longer cord
- Super_DaveExplorer50 gallon plastic barrel or garbage can cut in half and coiled in the bottom.
- wa8yxmExplorer IIIsoem people put both the 50 amp cord and some of the hoses in what I call wash tubs (Metal or plastic tubs about 3' across)
A tool I have might work.
Hose carrier strap
The link is to Wal*mart
I used it for ... Other stuff never for the 50 amp cord
Since I full timed I put the 50 amp cord in the car.. Then hooked the car behing the RV. Upon arrival at a 50 amp site I pulled in with the car.. Pulled up beside the power post and unloaded the cord. Then Backed the RV in and hooked up. - capacitorExplorerMove closer to the power pedestal and don’t use it. That is a big cord. Maybe a hose reel from Home Depot.
- Grit_dogNavigator IIIBigger bin? Coil it up tighter? Don't try to fit it in a bin and just roll it up like garden hose? Buy a cord reel? Cut it in half and add a plug to each end so each half is easier to handle? Wrap it and store around your propane bottles if they're exposed up front?
- dedmistonModeratorI have a cord and an extension and two Cord Caddy baskets, one for each.
Check out the Cord Caddy on Amazon.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
