chrispitude's avatar
chrispitude
Looks like 30psi ought to be plenty good for towing
Well not really, but no wonder there is so much confusion on the topic!
I have a 2006 GMC Yukon Denali XL with the factory tow package. I'm getting things set up to tow a 2019 Jayco X23E, which is around 6000lbs ready to travel. I don't know the tongue weight yet, but I'm guessing it's around 750lbs.
The door sticker lists the cold pressure as 30psi, with no additional ratings for increased loading:
The manual doesn't say much about the label:
It mentions a bit about not underinflating or overinflating:
and most interestingly, states that "The recommended cold tire
inflation pressure, shown on the label, is the minimum
amount of air pressure needed to support your vehicle’s
maximum load carrying capacity":
So 30psi is the minimum, and apparently I'm free to go above that. But how far above?
I'm running Vogue Signature V SCT tires in a P275/55R20 fitment. They are XL load range P tires, and the sidewall max pressure is 50psi.
The Tire and Rim Association (TRA) inflation tables for this tire size gives ratings up to 35psi.
My thinking at the moment is:
  • Since I'm aiming for the hitched-up front axle weight to be only 100lbs above the unhitched weight, I'll run 35psi cold in the front.
  • Since the rest of the tongue weight will be on the rear axle, plus I'd like to minimize squirm near the pivot point, I'll run 40psi cold in the rear.
Does this seem like a reasonable starting point?
  • chrispitude wrote:
    The sticker is missing on the door (thanks previous owner), but AFAIK the GFAWR is 3600 lbs and GRAWR is 4000 pounds.
    You're thinking 35psi front and rear, instead of 35psi front and 40psi rear?
    ? The picture of the placard you posted says 30/30, not sure where your "instead of" 35/40 comes from.
    I was thinking 35 rear, instead of the 30 on the label. But if the rear axle rating is 4K, the tires will support 500 lb more than that even at 30, so there's already a good margin.
    Probably best to stop by a CAT scale with your Yukon empty, just to get an idea of where it sits normally. That will give you a good feel for how much tongue weight and load you can add.
    Or, if you contact GM (or maybe even the dealer), and explain that the capacity placard is missing, they might be able to give you the numbers based on the VIN.
  • mike-s wrote:
    P275/55*20 is good for 2216 lbs per tire at 29 psi. So, about 4500 lb on the rear axle @30 psi. What's the RAWR? If less than about 4500 lbs, more pressure won't get you more capacity. And, I'll bet it's right around 4500 lbs - manufacturers spec tires and pressures to support the ratings they give. If the sidewall max pressure allows it, I might run an extra 5 psi when towing, but not more for treadlife.
  • P275/55*20 is good for 2216 lbs per tire at 29 psi. So, about 4500 lb on the rear axle @30 psi. What's the RAWR? If less than about 4500 lbs, more pressure won't get you more capacity. And, I'll bet it's right around 4500 lbs - manufacturers spec tires and pressures to support the ratings they give. If the sidewall max pressure allows it, I might run an extra 5 psi when towing, but not more for treadlife.
  • carringb wrote:
    What's your rims rated for?
    I have no idea. They're the factory GMC 20" peely-chrome wheels. That's another reason I'm not too keen on throwing 50psi in the rears to see what happens.
  • My p rated tires are 44psi max. I run 40 psi in them all the time..
    If I had XL tires I would also run 40 psi in them..
    No these tires do not work like LT tires where the more you inflate the more load you can carry.
    But thats me.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
