K3WEExplorerNov 16, 2019Loud Water PumpWe have a new camper and the water pump really resonates on the floor. I think the pump is fine, but it's bolted to the floor under the kitchen sink- and vibrates just right for the floor to really a...Show More
Old-BiscuitExplorer IIINov 16, 2019Sounds like the 'Factory floor monkey' way over tightened the pump mounting screwsThe rubber pads under the mounts should NOT be flattened/.over-compressedMounting screws should be SNUG ---just enough to hold water pump in placeLoosen those mounting screws then just snug them and give the pump a test runWith oump running lightly tighten each screw slightly if still vibratingAlso check the routing of the discharge hose which should be flex tubing vs rigid PEX pipe
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
