I have a 2013 Heartland Prowler 31TPS FW. It has been out a total of 5 times. We have gone dry camping once and all other had at least water and electricity. Last time we took it out, I had the ri...
The first thing I'd add to a water pump is an accumulator tank. This allows for water pressure to be maintained without the pump having to cycle on and off.
That, or a variable speed pump which only needs to run as fast as the water demand happens.
Either of those will solve the pump noise, assuming the pump, and the pipes are mounted with proper shock/vibration mounts.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
