kenvs's avatar
kenvs
Low bridges
We sold our motorhome a while ago and at 12'6" tall we had no worries about low bridges on interstates or secondary highways. We just bought a 5er that is indicated in the specs to be 13'6" tall. I will measure it for actual height and I have purchased a Motor Carriers road atlas which should help.
While driving along I-94 in Detroit I noted that some overpasses were indicated to have only 13' clearance. Further research has shown that these bridges are not listed in the road atlas.
Does anyone know of a good app that lists low clearances by state and route? The GS trip planner only indicates clearances under 13' which could end up being expensive. Most 5er height specs that I've seen in literature indicate 13' 4" to 13' 6".
Thanks for any input.
  • The semis are taller than you. As long as you see them going in the opposite direction you are good to go.
  • http://www.lowclearances.com for your existing GPS unit.
    or buy one with it already loaded in - usually a truck specific GPS unit.
    http://www.gps-planet.com
    http://www.gpscity.ca/questions?qid=31566
    I use these and have added additional files form other sources. Works for me.
    http://www.poi-factory.com/node/36115
    There are also phone apps that have mixed reviews.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
