DarkSkySeeker's avatar
Jan 20, 2020
Low clearance - cut this off?
The structure in my photo extends very low under my hitch. It is so low, it drags on most driveway entrances and exits. Other than making the hitch less adjustable for another rig in the future, is there any downside of bandsawing it off?
  • Yes you can trim it down a bit. But make sure you're only trimming the part that's in free air. I wouldn't cut anything that is between the clamped pieces.
    If you want to avoid cutting you could try disassembling the hitch and flipping that part over. But my guess is then it will stick up too high and interfere with the tailgate opening.
  • If you are that tight on ground clearance you may be better off with a trunnion type setup.
    Sorry, looks like you pointed to the drop hitch. I agree you could cut that or try a different drop.
  • I would cut it off, but leave it a little longer than the equalizer bars hang down. You may wind up having to replace them in the future
  • i would cut it off. Just leave enough material so it doesn't compromise the bolt hole above it.
    Barney
  • I cut off several inches on a couple of those, including the one I've been using for more than ten years. No problems what so ever.
