Mr__Steve's avatar
Mr__Steve
Low Clearance question
What, if anything , do people use to determine low clearance bridges, etc while traveling? Trying to avoid surprises. I use google maps, but it does not tell in in advance. Thanks!
  • Good Sam Trip Manager has a height feature that I like
    It has the following warnings you can set
    Show RV Warnings
    RVs Prohibited
    All roads where RVs are prohibited from driving.
    Low Clearances
    Show all low clearances below 13'6".
    No Propane Allowed
    Show roads where no propane is allowed.
    Propane Restrictions
    Show roads that have propane-related restrictions.
    Tunnels
    Show a warning for all tunnels.
    Bridges
    Show a warning for all bridges
    link below
    http://trips.goodsamclub.com/
  • Get behind a tall 18-wheeler. If they get through, you can.
  • The problem with using the Truckers Atlas is it doesn't list all the side and back-roads, ie like the one that leads to that obscure campground you are going to for the first time.
    If you use a GPS, there is a firm selling a POI file for it that lists all known (something like 50,000) low clearance (below 14 ft) locations in North America. See here
    As for utility lines, they are all supposed to be high enough (14 ft) to allow the clearance of legal vehicles, at all times and in all locations. This allows things like say, moving trucks, to move about and load/unload households.
  • My answer will not tell you about low bridges but will give you RV height. I placed a long 2x4 on top of my A/C so it overhung the side of the RV and measured to the ground from the 2x4. A/C was my highest point. As far as knowing low bridges in advance I am no help.
  • I plan my route using my Garmin. Then I check the route with my trucker’s atlas. The trucker’s atlas has all roads the trucks can travel on marked in orange. If any part of my suggested Garmin route is not orange when I look in the atlas, I do not follow the Garmin route. I then plan an alternate route and program my Garmin accordingly. This approach has worked well for 7 years so far.
  • K Charles wrote:
    Common sense and read the sign. Know how tall your rig is.
    That was a huge help to the op.... Yes there are signs on the highways to avoid low bridges and yes you should know how tall you are but that may not be enough if you get off the beaten path and roll up on something too low. I thought there was an app for this, read about it here awhile back.
    I've only gotten in this situation once so far by accident, wrong turn with a 40' 5er that almost put me into a very old small town with very low hanging wires. Luckily I was able to dip off into a parking lot and get turned around.
    Not always about common sense and knowing how tall you are.
  • We have a truckers book of maps and if going back roads I check if there are any listed on that road. Flying Js sells the book.
