bid_time
Jul 10, 2014Nomad III
all you have to do is cut the tube off above the hole and put a new ball valve on the end of the cut off line. Get a ball valve sized properly for the size of the line. Take the cut off piece of tube with you to the hardware store, They should be able to identify the tube material to ensure you get the proper size valve and the proper valve type to ensure its compatible with the pipe material.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
