beaubeau's avatar
beaubeau
Low point drain valves replacement
Hi. All 3 of these valves are leaking.
https://ibb.co/9tky4wT
I cut 1 out and bought a SharkBite PEX valve.
Apparently the lines look like (to me) PEX, but it’s not quite PEX.
The PEX rings just wad up the line, like this:
https://ibb.co/hYd0GgF
Any ideas?
Thanks a lot.
  • I don't know what size tubing you have, but it looks looks like you used a 3/8" fitting when you need a 1/2" fitting.
  • I use this type PEX crimps
    Inexpensive tool! Use same style on my sprinkler system.
    Push to fit fittings are also good. Sharkbite is one brand but little higher in price.
  • I think you’re right! I think I used the 3/8 die for 1/2” line, thank you!!
  • Second photo shows a compression ring quite possible the wrong size.
