beaubeauExplorerApr 08, 2022Low point drain valves replacementHi. All 3 of these valves are leaking. https://ibb.co/9tky4wT I cut 1 out and bought a SharkBite PEX valve. Apparently the lines look like (to me) PEX, but it’s not quite PEX. The PEX ring...Show More
beaubeauExplorerApr 08, 2022I think you’re right! I think I used the 3/8 die for 1/2” line, thank you!!
Related ContentLow Point Drain Valve ReplacementLow point drain valve questionLow point drain valvesReplacement Lights for TTVoltage Dump Valve Replacement
