VintageRacer
Sep 26, 2014Explorer
Rear suspension is easy enough to lower, you can remove the 350 spring block and put in a 250 spring block, or even a smaller block, you can get the springs re-arched, different things can be done. The front is harder. You have the twin I-beam suspension on the E350, lowering it will change the camber, you will probably have issues with the bump stops, etc. I have read of modified I-beams that accommodate those issues.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
