carringb
Sep 26, 2014Explorer
Your proposed method will not work on the E-series. There are no lift blocks, and the shackles are already underslung.
What might get you enough drop is removing the lowest leaf spring, aka the "overload" spring. You then restore the spring capacity with a Firestone airbag kit.
Or, you can do full air-ride, but that might cost more than a bigger garage door.
http://dallassmithcorp.com
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
