christopherglen
Sep 26, 2014Explorer
If the shackles are in tension, longer shackles will lower the van, effecting little else. If the axle is under the spring, and there is clearance in the wheel wells, moving the axle above the spring would lower the rear the height of the axle + the height of the spring pack. A third option would be pulling some leafs out and replacing them with airbags.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
